NVG 149 t-case ?
Old Jan 20, 2009 | 06:08 PM
Default NVG 149 t-case ?
just curious if a NVG 149 AWD t-case uses the same drive shafts front and rear as the electric shifted 4X4 t-cases, would the 4X4 t-case bolt right in using all the same parts??? without the elctrical parts of course.
Old Jan 23, 2009 | 12:03 PM
Justin @ EAD Performance's Avatar
I believe the splines are the same for the front and rear drive shafts. However I am almost positive that the NVG149 is shorter than its 4WD version. I am not 100% positive though.
Old Jan 24, 2009 | 08:38 AM
specifically the reason i was asking was swaping a front drive shaft from a 2500 hd with a 4l80e in it. the rear will be a custom piece.
i know people with 4X4 cases and use the front shaft and was just woundering if it works with the AWD cases
turbo6c3
Oct 5, 2015 06:11 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
1bad2k
Sep 7, 2015 09:26 PM
mayko
Sep 7, 2015 12:24 PM
alex226
Jul 16, 2015 10:55 AM
