np261 Input Shaft
Old May 18, 2021 | 05:23 PM
redline09's Avatar
Registered User
Default np261 Input Shaft
I went to to try and swap in an input shaft from a np261 into my np246 transfer case and found out the bearing in the shaft is too big because it is 32 spline. I need the 32 spline shaft because I just did a 4l80e swap in my 2005 Sierra. My question is, is there a bearing out there that I could buy that would work so I could use the 261 input shaft in the 246 instead of having to buy a different input shaft? If so then I need a part number. If not then I need a part number for the correct input shaft. Thanks
Old Jun 9, 2021 | 11:42 PM
Mike120's Avatar
Registered User
I believe there is a narrow and wide bearing, I had both come in my rebuilt kit for my np241 Tcase, I went from the 4l60e input to the 4l80e 32 spline one. Not sure if the 261 uses the same as the 241 but if worse comes to shove but a rebuild kit and it should have both. Belive it scalled a pocket bearing and its like a cup.
gmc123
Jan 19, 2018 06:41 PM
artypyro
Aug 23, 2008 01:46 PM
Lord Aries
Oct 23, 2007 07:26 AM
Faze2183
Jan 5, 2007 06:49 PM
