normal tailshaft play
Old Feb 8, 2015 | 08:03 PM
LPCWS6's Avatar
Default normal tailshaft play
Does this look like normal up and down play in my tailshaft. Side to side is the same. Seems excessive to me. it's a 4l80 to a 2 piece driveshaft on a 2wd ecsb Silverado
https://www.youtube.com/watch?v=MEji...ature=youtu.be
Old Feb 8, 2015 | 08:07 PM
FFDP's Avatar
Thats alot of play.
The u-joints look shiney and new though, are they the correct size or have any grease in them??
Old Feb 8, 2015 | 08:15 PM
Gadgetized's Avatar
Mine doesn't have anywhere near that much play. Are there grooves in the yoke when you slide it out? I would get a bushing and put it in the tail housing just to be on the safe side. It is an easy job to do too.
Old Feb 8, 2015 | 09:14 PM
LPCWS6's Avatar
All that's less than 6 months old. Jakes stage 4 and a custom Driveshaft Specialist out of Texas driveshaft. I didn't install any of it so I'm not sure if it was sloppy from the get go or not. I've been noticing a little vibration that felt like maybe a u joint was going out, and that's what I found. I spent too much money to be having these problems already!
Old Feb 9, 2015 | 11:11 AM
tgui's Avatar
Is your suspension considerably different than stock? I think universal joints need a certain amount of angle applied when rotating to keep the needle bearings healthy?
Pulling a shaft is pretty damn easy. I'd do that, make sure the yoke isn't damaged and also inspect the needle bearings. Careful though.
Old Feb 9, 2015 | 05:13 PM
LPCWS6's Avatar
I didn't feel any play in the u-joints. I contacted the shop that did the work and they are looking into it for me. I don't plan on being the one who fixes it considering I didn't order or install any of that stuff myself and it's all only about 6 months old.
lukn4trbl355
Oct 21, 2015 11:19 PM
lxcoupe
Oct 4, 2015 08:07 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
KleanKustoms
Sep 30, 2015 05:07 PM
TrickTurbo
Sep 23, 2015 08:41 PM
