noise in bell housing
Old Oct 16, 2006 | 08:29 AM
silver-mod-o's Avatar
Hunt&Fisherator
Default noise in bell housing
it sounds like a playing card in my bicycle spokes... I done know what it is, it changes with RPM and volume increases and decreases sometimes... I am stumped, and I dont want to take this thing back apart again unless I absolutely have to... it still runs and drives fine, just makes a noise.
Old Oct 16, 2006 | 08:32 AM
BlackGMC's Avatar
Resident Retard
Didn't you just buy a new TC and Tranny?
Old Oct 16, 2006 | 08:45 AM
Hunt&Fisherator
yep... new FLT-5 and PI converter... I had a problem with the converter going in because of the bolts but I thought I solved that... I am thinking I have a cracked flexplate.... I'm not sure... I'd like to know where to look once I do go back in it.
Old Oct 16, 2006 | 08:50 AM
Rhino79's Avatar
9 Second Club
Either that or a loose bolt probably.
Old Oct 16, 2006 | 08:53 AM
Hunt&Fisherator
I hope these things arent loose... I just about dipped them in lock-tite when I put them in... I have already had that problem...
Old Oct 16, 2006 | 08:56 AM
bluecajun5.3's Avatar
11 Second Truck Club
i'd have to say flexplate also.
any vibrations?
Old Oct 16, 2006 | 09:02 AM
Hunt&Fisherator
any vibrations?
no vibes, everythings smooth as can be... just a noise and you can kinda "feel" it ticking... when the converter bolts backed out the first time, the heads were hitting the back of the block!!! there was a LOT of screwed up pressure being put on the flweplate which it what is would cause it to crack if that is the problem.
it only sounds like its one side of the plate though. or one bolt... I guess It'll be going back on the lift Wednesday when the shop opens up.
The first time I heard it I was going down the freeway next to a tall barrier and heard the noise coming off the wall... it sounded terrible... as soon as I lifted off the gas though it went away. and it just kinda comes and goes...
Old Oct 16, 2006 | 09:09 AM
ZR1 DREAMING's Avatar
Ben, I'm guessing it's your flexplate. Especially since all your teeth are no longer in tact. I'm surpirsed you haven't had slips with your starter starting yet.... or have you?
Old Oct 16, 2006 | 09:14 AM
Hunt&Fisherator
no slips or skips.... not even any weird noises on startup....
Old Oct 16, 2006 | 09:59 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
That right there would be enough for me to put a new flexplate in
Damn Ben
If you really dont want to pull the trans then pull the starter and make sure the TC bolts are tight.
