no third no forth sometimes nothing at all
Old Mar 17, 2009 | 06:02 PM
TURBHOE's Avatar
Default no third no forth sometimes nothing at all
well we dropped a 383 ls1 into a 97 gmc truck. has a "built" 4l60e behind it. today he lost 4th gear all the way won't go in it at all. at one point all the gears were out including reverse. he shut it off for a few, started it back up and all gears were there again. then later on he lost 3rd along with forth.
also since we installed it if the torque converter locks the whole truck shake very badly. so i had to program it to stay unlocked. what could this be? just bad pressure?
Old Mar 17, 2009 | 06:49 PM
truckmann's Avatar
Is it a new trans or was it working fine behind a different engine?
Old Mar 17, 2009 | 06:57 PM
TURBHOE's Avatar
its new. it has been working fine for the past couple weeks now. well, fine besides the tcc thing. that has never worked good.
Old Mar 17, 2009 | 08:19 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
The vibration may be converter clutch failure and the other syptoms related causing a trans failure but no way to be sure short of tearing it all down and looking, But thats certainly next on the agenda I would say
Old Mar 18, 2009 | 07:54 AM
TURBHOE's Avatar
the converter is also new. we called the guy who made it and he said it was the trans. i put full line pressure to the tcc and it still pulsed really bad. i turned it off in fear of harming the motor thats how bad it was.
Old Mar 18, 2009 | 08:20 AM
I still tend to think the converter is the primary issue, Pull the pan and see just whats in there.
Old Mar 18, 2009 | 10:55 AM
TURBHOE's Avatar
will probably do that.
Old Mar 18, 2009 | 11:06 AM
TURBHOE's Avatar
WHAT COULD CAUSE LOSS OF ALL GEARS INCLUDING REVERSE? oops sorry about the caps.
Old Mar 18, 2009 | 11:44 AM
TURBHOE's Avatar
he now has no 3rd or 4th at all.
Old Mar 18, 2009 | 02:20 PM
If the filter clogs up with debris you can loose everything though ussually after it sets and drains back through a little its will come back for a short time
