no lock-up
Old Mar 6, 2015 | 08:17 PM
askkmb's Avatar
Default no lock-up
Hello, i recently tuned a truck and i cant get the lock-up to work. 04 Silverado and we did a 6.2 and 4l80e swap to it. First we just swapped in the 6.2 and everything worked great. Later swapped the 4l80e to it and lock-up hasnt worked since then. I can get it to lock but only if i manually engage it in the scanner. I left all the stock values for tcc in the pcm from what the 4l80e segment had, just increased tcc duty cycle. I will attach the tune. Still needs some work but i would like to fix this first.
File Type: hpt
Old Mar 6, 2015 | 09:33 PM
TheBeeblebrox's Avatar
You need to change the settings under the Minimum Throttle Release table, try this: max out Low and High Speed VSS to 256 and zero out the 4 TPS settings.
This is how my tune is set up and the converter locks up when commanded every time, and stays locked at 0% throttle too.
Old Mar 6, 2015 | 10:30 PM
askkmb's Avatar
Ok, i will try that. But still shouldn't it lock with those values? Those are the stock values and i just looked at my tune and it is set at the same values as this tune. Mine works flawlessly.
Old Mar 6, 2015 | 10:42 PM
Not too sure, but I was having problems with inconsistent/no lock-up with the stock settings in that table and searched hpt forums and found those settings so I gave them a shot and it worked.
Old Mar 7, 2015 | 08:21 AM
askkmb's Avatar
Well im going to try it. Thanks.
Old Mar 19, 2015 | 01:02 AM
askkmb's Avatar
Got some updates. I still got no lock up and i checked and i have a dtc: P2761. Anyone has any ideas to try? Like i mentioned before i can lock it up with HPT scanner but it doesnt lock by itself. Any ideas?
Old Mar 19, 2015 | 07:42 PM
According to google that code is for the Torque Converter Clutch Pressure Control Solenoid Valve Circuit. So possibly something wrong in the wiring harness or a bad solenoid.
Might be a good idea to check the wiring for a bad ground fist?
Old Mar 20, 2015 | 12:58 AM
walledition's Avatar
Check the engine harness to transmission conector, cant remember exacly but i remember having the same problem and i placed a color wire wrong
g6t6o
Sep 26, 2015 10:57 AM
MileHighSierra
Jul 6, 2015 02:41 AM
Yohns Kustom Fab
Jun 27, 2012 08:25 PM
TGriz
Jul 22, 2010 12:24 AM
1ImperialSS
May 3, 2006 10:11 PM
