Nnbs driveshaft limit?
Old May 19, 2016 | 12:58 PM
FFDP's Avatar
Right, my point was just with the stock driveshafts itself.
Old May 19, 2016 | 01:03 PM
vettelovralexand's Avatar
The factory shaft is weak from both torque capability and critical speed. For high power, I don't know what level people are ditching the stock shaft, however, lots of people even with factory power levels chuck the factory 2wd shaft because of exceeding critical speed.
Old May 19, 2016 | 01:04 PM
RS/SS 4.8's Avatar
10 Second Truck Club
6" alumimum driveshaft, damn i didnt know they made one that big. I thought 5" was the biggest one they made lol.
Old May 19, 2016 | 04:31 PM
rednekferlife101's Avatar
Thanks guys!! I have my drive shafts out and the front one is heavier than the rear one haha. I'm going to a 4l80e swap but the drive shafts should be damn close to the same length. I'll see if I can keep the front one and get a new rear shaft made up just to be safe then!
Old May 19, 2016 | 09:09 PM
tgui's Avatar
My 80e swap needed a new front and custom rear.
Old May 19, 2016 | 09:59 PM
Do you know the length differences? The 4l80 is a little longer but the transfer case adapter is shorter so I figured it would be close haha
Old May 19, 2016 | 10:27 PM
Wolftrk99's Avatar
1 11/16 or something.... May be different on nnbs though....
Old May 19, 2016 | 11:11 PM
This is the difference between the t case adapter between the 6l80 and 4l80
Old May 19, 2016 | 11:14 PM
tgui's Avatar
That sounds right.
Also my custom driveshaft is steel good to 130mph+ and 600ftlbs at the wheels according to the specs and dimensions I provided the builder. I have a Yukon so my shaft length wasn't too much. I also valued strength and lower $$ over low 1/4
Old May 20, 2016 | 01:07 AM
I gotta get the t case on the trans then I can get some measurements. Here's some pics of how the cross member and the mount were. It was about an inch and a half or so back from where the 6l80 mount bolted. So I cut the cross member and got that all welded up. Little overkill but rather it be sturdy!
