nnbs bilstein lift nose high
Old Apr 30, 2014 | 08:15 PM
07NBSChevy's Avatar
Default nnbs bilstein lift nose high
Ok guys, just installed Bilstein 5100's all around and set the fronts at top clip position. it seems to have lifted my truck 1/2 higher than the back. measurements are, Front 23-1/2'' and Rear 23'' from axle centerline to bottom of fender. passenger side for some odd reason sits a tad higher (1/8-1/4'' higher), possibly because of fuel tank on driver side full of fuel. Anyways, it seems to have lifted my truck 3'' in the front, are you guys running taller blocks in the rear? I see Ready lift sells an OEM style block that's 1" taller than stock which would put me about right at a 1/2'' Rake. My buddy has a 2010 Sierra and uses Bilstein 5100's on top notch and it sits level, actually about a 1/8 lower in front which looks perfect. He has a 6.2 if that matters.
Old Apr 30, 2014 | 09:50 PM
07NBSChevy's Avatar
Just noticed I posted this in the wrong section. Can a Mod move this to "Gm Drivetrain and Suspension"
Old May 1, 2014 | 09:03 AM
pezboy's Avatar
Can they adjust down any? I would lower the front to match the rear instead of raising the rear. 3" is quite a bit without upper control arms and a differential drop.
Old May 1, 2014 | 12:26 PM
07NBSChevy's Avatar
After remeasuring it really sits a little over 2.5" higher. I had a 3" leveling kit on it before it the angles now are not nearly as bad as they were with the 3" leveling kit. With the front end off the ground at full droop they do not touch the UCA stops, with the 3" they did.
Old May 1, 2014 | 12:55 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Done!
Old May 1, 2014 | 06:19 PM
pezboy's Avatar
Taller rear blocks won't hurt then. The factory ones are 1.25" IIRC.
5.3Okasai
Mar 9, 2022 01:07 PM
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Nov 5, 2015 06:49 AM
signguy62
Sep 20, 2015 02:05 PM
Ketis
Jul 23, 2015 12:37 PM
