New tranny and no movement???
Old Oct 22, 2006 | 09:09 PM
litreddevil's Avatar
Banned
was their a space between the flywheel and verter when you got the trans bolted up if not you did not have the vert in all the way and when you, bolted the trans it pushed the verter into the pump and when you started it boom they broke it happens.
Old Oct 22, 2006 | 09:12 PM
pewterZ71's Avatar
well there was a space but it closed up when i put the flywheel bolts in
Old Oct 22, 2006 | 10:39 PM
pewterZ71's Avatar
no fluid running through the cooler lines i guess i did mess it up....dammit!!!!
Old Oct 22, 2006 | 11:10 PM
Wilde Racing's Avatar
How do I change this text
When I did mt last torque converter swap, it took awhile before trans pumped the fluid and would move. we are talking like a full min of nothing. but I did not pull a cooler line like Vince said too....
How long has the truck ran for?
Old Oct 23, 2006 | 01:30 AM
pewterZ71's Avatar
i didnt have it on long....should i leave it on a while?? would the fact that i have only 8 quarts in it affect it too?? i just didnt wanna overflow the dam thing if its not pumping it through
Old Oct 23, 2006 | 02:21 AM
I dont know, I wouldn't add any until it pumps the stuff in the pan down below the add mark.
You are sure there was a gap between the Flex plate and torque convereter with the bellhousing bolts in and tight?
I can tell you one thing, Vince knows a HELL of alot more about trannys than I do, go with what he said. lol
I personally would run it for a few more seconds. but thats just me, and I like the sound of crap braking because I'm doing something dumb.
one other thing I'd check before pulling the damn thing out, I'd pull the pan and make sure there is a filter in there and it is fully seated.....
Old Oct 23, 2006 | 02:24 AM
pewterZ71's Avatar
im confused with the gap thing...i bolted up the tranny and i know that to make sure its seated well there has to be a gap...now when i put the converter bolts on it brough it forward until the bolts were nice n tight...so i dont get how there would be a gap :S
Old Oct 23, 2006 | 02:32 AM
That is the way it should be. as long as the gap wasn't to big, ther is a spec, but I'm not sure what it is.
I'm going with something else is causing the problem......
Old Oct 23, 2006 | 02:35 AM
pewterZ71's Avatar
dam im trying hard not to have to remove the dam thing again...ima keep working on it tommorrow thankx for the help guys...any other suggestions just keep postin
Old Oct 23, 2006 | 07:32 AM
Batman WS-6's Avatar
Originally Posted by Nickvrebel
it's easy to break the pump if you didn't seat the converter fully
Yup, I almost did that on my T/A. Another silly question...you did plug in the connector right? If not it either sound slike there isn't enough fluid or a bad pump. You definately need to pull the pressure line and see if it is moving fluid.
walledition
Feb 24, 2026 03:27 PM
Wolftrk99
Dec 3, 2015 08:12 PM
sTNT971
Sep 26, 2015 06:27 AM
jscherbs
Sep 24, 2015 12:51 PM
mayko
Sep 7, 2015 12:24 PM
