New tranny and no movement???
Banned
was their a space between the flywheel and verter when you got the trans bolted up if not you did not have the vert in all the way and when you, bolted the trans it pushed the verter into the pump and when you started it boom they broke it happens.
How do I change this text
When I did mt last torque converter swap, it took awhile before trans pumped the fluid and would move. we are talking like a full min of nothing. but I did not pull a cooler line like Vince said too....
How long has the truck ran for?
i didnt have it on long....should i leave it on a while?? would the fact that i have only 8 quarts in it affect it too?? i just didnt wanna overflow the dam thing if its not pumping it through
I dont know, I wouldn't add any until it pumps the stuff in the pan down below the add mark.
You are sure there was a gap between the Flex plate and torque convereter with the bellhousing bolts in and tight?
I can tell you one thing, Vince knows a HELL of alot more about trannys than I do, go with what he said. lol
I personally would run it for a few more seconds. but thats just me, and I like the sound of crap braking because I'm doing something dumb.
one other thing I'd check before pulling the damn thing out, I'd pull the pan and make sure there is a filter in there and it is fully seated.....
im confused with the gap thing...i bolted up the tranny and i know that to make sure its seated well there has to be a gap...now when i put the converter bolts on it brough it forward until the bolts were nice n tight...so i dont get how there would be a gap :S
I'm going with something else is causing the problem......
Originally Posted by Nickvrebel
it's easy to break the pump if you didn't seat the converter fully
