New TC and Converter Limit Valve Install Gone Wrong
Old Nov 29, 2013 | 03:49 PM
slowmo934's Avatar
Default New TC and Converter Limit Valve Install Gone Wrong
Major trans fluid pouring out of upper vent tubing. It actually empties the entire trans!! When idling no fluid pours out, in gear it FLOWS. I did the converter limit valve modification my self and re installed the pump and new PI triple disc TC. What did I mess up so bad on? I believe my next step is to get it hauled to the transmission shop. Please help if you have any input on what the problem may be. Thank You!
Old Nov 29, 2013 | 07:00 PM
slowmo934's Avatar
Please help. Maybe an order to Jakes for a stage 4 with trans brake will help?? haha,, Well we will have to see how some of my investments pay off in the next two weeks...
Old Nov 30, 2013 | 08:57 AM
Vince B's Avatar
What year is the trans you are playing with?
Old Dec 1, 2013 | 12:43 PM
slowmo934's Avatar
It's on a 2005 Suburban 2500. 4L80e
Old Dec 1, 2013 | 07:59 PM
Vince B's Avatar
I have a couple of tips for you. On the back side of the late pumps there should be a small oil deflector to keep oil from coming right out of the pump and blowing right into the vent tube. This is held in place by one of the pump bolts. I would make sure that is there and go over everything you did on your install. Also on the late limit valves you need to grind a small portion of the OD of the valve so the spring sits correctly. Not sure if either of these apply to you but figured it can't hurt to make sure you have them correct.
Old Dec 1, 2013 | 08:34 PM
slowmo934's Avatar
Vince thanks for the tips! I did all the above on the install, however I do believe I need to check that oil deflector again you mentioned. That oil deflector and the way you described it seems like the culprit. Time to drop the trans again...
Old Dec 1, 2013 | 08:40 PM
kelsey_canard's Avatar
What exactly does this valve do? I recently got my ptc converter installed and I am having problems. It really feels like the tc clutch is dragging at idle. I did not do this mod to the pump.
Old Dec 1, 2013 | 08:44 PM
slowmo934's Avatar
wittrans.com has that part and describes it as so. I remember putting it back together with that part. Question is did I put it back in the correct location.
D34507E-4 Retainer, 4L80E(Metal)(Oil Deflector)(1 Pump Body Bolt Holds This On)97-Up
$9.57
Old Dec 1, 2013 | 08:51 PM
slowmo934's Avatar
If I remember correctly it is installed to help out with idle conditions. Maybe somebody more knowledgeable can chime in.
Old Dec 1, 2013 | 08:56 PM
What exactly does it help at idle conditions? Do you know? I seem to have low line pressure at idle, but fine with rpms.
