New GM frame and axle prep
Old Apr 19, 2007 | 08:44 PM
03sierraslt's Avatar
yes it does but that would take a **** load of brake cleaner @ like 5bux a can.....
Thats my point, Hot High pressure water does wonders. Most pressure washers have the ability to also mix in degreasers as well. At least my old mans does.
Old Apr 24, 2007 | 09:51 AM
Colby 04's Avatar
Originally Posted by TurboGibbs
OK, it is wax. And you guys are suggesting 50 cans of carburetor cleaner over a 1500+psi pressure washer blowing 190* water? My way it is all gone in 15mins tops, your way it is gone in 15hours.
Don't get so offended
Old Apr 24, 2007 | 09:54 AM
BlackGMC's Avatar
Resident Retard
Go to walmart and buy some oven cleaner, not the cheap stuff. Hose it down with oven cleaner and let is sit for a little bit then wash it off with a hose. That is what I have used to remove undercoating from my mustang.
Old Apr 24, 2007 | 10:09 AM
Tootall's Avatar
Red face
great idea, but he might need a suit if he goes this way.
Old Apr 24, 2007 | 10:15 AM
Holty's Avatar
Notorious BIG
sorry guys, for some reason i wasn't getting email notifications that there were replies to this post. so what is the concensus then? rent a hot water pressure washer or use the brake cleaner? somoene asked why i want to do this its because i want to paint my frame nice and shiney black. here are the pics:
you can also go here to view/read about my rebuild:
https://www.performancetrucks.net/fo...9&page=1&pp=40
Old Apr 24, 2007 | 10:16 AM
Holty's Avatar
Notorious BIG
Originally Posted by Colby 04
Are you talking about that black undercoating they put on them?
If so, that stuff just melts right off when you spray it with brake parts cleaner.
yes, thats what i'm talking about.
Old Apr 24, 2007 | 10:26 AM
BlackGMC's Avatar
Resident Retard
Another idea is to call up a mobile media blaster to come media blast the frame where it sits. They usually charge by the hour, but from the looks of it it should probably take less than an hour. IMO Media blasting will leave the frame in the best possible condition for paint.
Old Apr 24, 2007 | 10:34 AM
dewmanshu's Avatar
Moderately Differentiated
shiny black? jeeesh...for crying out loud. Please tell me you are putting everything back together next that rusted wheel barrel. LMAO
Holty's Avatar
Notorious BIG
thats a great idea, im going to see about finding one locally.
Old Apr 24, 2007 | 10:45 AM
TurboGibbs's Avatar
From my experience with media blasting and old grease is it is slow go. It removes it slower than it removes rust. It kinda smears it and this coating has similar consistancies to old caked on grease, or a little softer maybe.
If you do the hot pressure washer deal a tyvex suit and faceshield woud be a must but with the hot water you may not have to get very close. Might could just hit it from a distance while it melts it off.
Why don't you just test some things out. Go get 1 can of good Carb cleaner, brake cleaner, and Oven cleaner and test them out?
