Need suggestions for new rear end
I need a rear end that can handle around 900rwhp in my Tahoe.I'm investigating what alternatives are out there,I'll also need a really strong posi because a spool is not an option.If anyone has any suggestions,I would greatly appreciate your input.
A 10.5 14 bolt would do it but those things are heavy as hell. I'd probably do a full aftermarket 9" with a heavy nodular center section, 33 or 35 spline axles, aftermarket housing (thicker) with a brace kit. The only issue is with 35 spline the only differential you can get other than a spool is a Detroit Locker.
Also, Dana 70
Also, Dana 70
Also, Dana 70
Also, Dana 70
I have a 10.5" 14-bolt converted to non-float, but this is not what I would choose again if I were to have to do this all over. The center has withstood the worst I can throw at it with 4.56:1 gears and an Eaton posi. A big part in its strength is in having bearing on both sides of the pinion gear, like a Ford 9". The weakness on my setup is the ball bearings at the ends, in my opinion. After one evening of some donuts and drifting I got some strange noises from one of the bearings and discovered upon disassembly that the retainer rings for the bearings were bent and some of them were not positioned correctly - basically it destroyed the bearings. Now these bearing are not different than the those used on 9" Fords or even in NASCAR, they are pressed onto the axle shaft and then retained by a collar BUT they do not hold up well to a three ton vehicle being flung around a tarmack like it was a go-cart.
If I have to start over with the rear end again I will be looking into these companies that make 6-lug hub for a true full-float 10.5" 14-bolt.
Geartechhd makes some:
www.geartechhd.com/gallery/displayimage.php?album=2&pos=0
Also, Industrial Offroad:
www.industrialoffroad.com/gallery/album03?page=1
No sponsor on this site sells anything even remotely like any of this stuff, so there you have the direct addresses.
Bullet-proof rear ends for our trucks have to be custom built, unfortunately. Nobody has figured out there there is a demand for an off-the-shelf bolt-in replacement that can handle the kind of torque, weight, and 6x5.5" wheels that we need. The off-road guys are the only ones that come close, but like has already been said - a 10.5" 14-bolt is one heavy ****.
Edit:
I know a guy with a RamJet 502 with a 250-shot that has a 9.5" 14-bolt with 4.10:1 gearing. It's making less power than your target and the cover bolts on the differential walk themselves out. This is a telltale sign the housing is flexing. I've never had that problem with the 10.5" and 4.56:1 gears.
Edit:
