need some quick help. thread pitch/size
Old Mar 6, 2007 | 01:30 PM
silver-mod-o's Avatar
Hunt&Fisherator
Default need some quick help. thread pitch/size
Does anyone know the specs on the bolts that hold the U-joint straps into the rear yoke? I'm going to get some grade 8 bolts today for it but the truck and bolts arent anywhere close to me....
also, the thread pitch and size of the cooler line fittings that go into the radiator? I'm getting some plugs for those holes as I wont be needing them anymore. I have to get to the fastener place as soon as I get a chance so please let me know.
Old Mar 6, 2007 | 03:11 PM
Tootall's Avatar
off topic:
Do you have any pics of your cooler lines? How did you run the tubing?
Old Mar 6, 2007 | 03:19 PM
hERE DUDE....5/16 - 24x1.3 bolts
Old Mar 6, 2007 | 03:22 PM
Hunt&Fisherator
you da man...
do you happen to know the size for the radiator fittings? 'm pretty sure its just NPT stuff but I dont know the size.
i just so happen to have 4 of these bolts left over from my new slip yoke install if you can't find em'
Old Mar 6, 2007 | 03:23 PM
you da man...
Hmmmm...hang loose'
Old Mar 6, 2007 | 03:26 PM
you da man...
There's 2 diffrent ones available....either 9/16 x 18 or 5/8 x 18x 13/32
Old Mar 6, 2007 | 03:27 PM
Hunt&Fisherator
Originally Posted by Tootall
off topic:
I had some -6AN hoses made up with fittings on one end and none on the other. the end with fittings will just thread on to the adapters on the trans case with some 45* ends and the one end will just slide and clamp onto the cooler ends. the hoses will be routed outside the frame rails in order to keep them away from header heat etc etc... and a little bit cooler. Its pretty simple. I'll get pics when the whole thing gets installed this weekend.
Old Mar 6, 2007 | 03:29 PM
Hunt&Fisherator
what would I need to ask for just to get some plugs for the holes??
Old Mar 6, 2007 | 03:32 PM
jUST GO TO YOUR LOCAL HARDWARE STORE AND ASK FOR SOME 9/16 OR 5/8 PLUGS
