need help on 4/6 w/20's
Old Nov 16, 2005 | 09:38 PM
slammedS10's Avatar
Default need help on 4/6 w/20's
I already did a search and couldnt find anything. The problem is that I bought a 4/6 drop, but I have 275/45/20's, will this drop be ok??? I wont mind if I cant crank the wheel to full lock, my concern is if the tire is too tall for this drop.
Thanks alot guys, Ohh p.s. Its a reg cab long bed.
Old Nov 16, 2005 | 09:42 PM
Z284thgen's Avatar
11 Second Club
kinda been wondering the same thing as i got a reg cab SB but havent really foundany good info yet
Old Nov 17, 2005 | 07:34 AM
leochevy2001's Avatar
try asking the same ? on gmfullsize.com.
Old Nov 17, 2005 | 08:01 AM
slammedS10's Avatar
For some reason it wont let me log on over there. Thats why I am asking in here, I am sure out of 30,000 members on this site some will know the answer.
Old Nov 17, 2005 | 08:10 AM
were you banned? is your screen name the same over there?
Old Nov 17, 2005 | 08:29 AM
slammedS10's Avatar
No My screen name is different, they sent me a new password and evrytime I try to log on it says Invalid.
Old Nov 17, 2005 | 03:41 PM
02BlueStepside's Avatar
It all depends on the backspacing on your wheels. Do you know what the backspacing is? If you don't know the backspacing, offset will work too. That tire will fit with the drop since its about the same size as the stockers (height), but the position of the wheel will determine if it tucks inside the fender.
Old Nov 17, 2005 | 06:07 PM
slammedS10's Avatar
I am not sure what the back spacing is, here is a picv, maybee this will help.
Old Nov 17, 2005 | 11:33 PM
angelofdeath's Avatar
actually you're fine.i'm doing a 4/6 drop and had the same tire size before like yours but changed to a 265/35/22's. anyway the height difference is only 2cm . 275/45/20 will be jst right. actually i found out that 285/35/22's would fit a 4/6 drop. thought u guys might wanna know.
Old Nov 18, 2005 | 03:14 PM
What wheels are they? Most sites usually post the backspacing/offset on the website.
Backspacing is key. For instance, if I were to put a 275/45/20 tire on my wheels it would not tuck and would hit the fenders. Yes, the 275/45/20 tire will fit, but if the wheels do not have the correct backspacing, the wheels will not tuck inside the fenders.
