Need a good converter for a mild cam in a Z71
Actually. If you tow that much, I would say go with the 2400-2600 300mm Circle-D. If you get a performabuilt transmission, (at least the lvl 2 I know for sure), it comes with an external trans cooler. Or you can opt for the trucool 40k which you can get from Circle-D when you order your stall (assuming you get it from there). The 278mm converters stall higher, but they're rated to tow less at 4000lbs, but if you're going to tow anything close to that weight, with one of those stalls, you'd almost have to have the 40k cooler I'd think.
mzoomora
01-03-2016 07:06 AM
FlowmasterMufflers
07-22-2015 01:29 PM
