Nasty high freq. vibration after 4.10 install
Old Jul 31, 2012 | 09:14 PM
DrewSleeperSilverado's Avatar
Registered User
ok, i'll rotate it 180 & then drag the driveshaft to a shop regardless. i preloaded the bearings to about 20 in lbs.
Old Aug 1, 2012 | 01:49 AM
fast84's Avatar
Driveshaft for sure! Hope you have better luck with your aluminum unit than I did with my steel one. Finally had to get a heavier gauge bigger diameter one made that was high speed balanced. The factory one came out at about 90 after the 4.10's and did $1700 worth of damage! Don't run it very fast until youve gotten it balanced.
Old Aug 1, 2012 | 06:48 AM
Registered User
Thanks for the heads up fast...that's my sweet spot. Around 90 its at it's worst. Im thinking im gna have to change to a steel shaft. Cant find anyone in town that can balance AND weld an alum shaft... WTF?
Old Aug 1, 2012 | 08:29 AM
Registered User
Update: None of the "drive train/drive shaft" shops here in Odessa could do a balance over 2,000RPM much less do any kind of Alum welding. Sending it to Drive Shafts Unlimited in San Antonio. Hopefully this will fix the problem.
Old Aug 1, 2012 | 12:35 PM
fast84's Avatar
Good deal.
Old Aug 1, 2012 | 09:54 PM
Area47's Avatar
your driveshaft is about to let go.
Old Aug 1, 2012 | 10:12 PM
iamkeniff's Avatar
Just call driveshaft specialist and have them build you a real driveshaft
Old Aug 2, 2012 | 08:49 AM
More than likely, that truck had 3.73s stock. There is no reason why that shaft shouldn't be able to handle 4.10s at 85mph. I have seen people drop the shafts when taking them out, and put a kink in the tubing. I've also seen the yokes damaged by improperly changing the u joints.
Old Aug 2, 2012 | 11:00 AM
Registered User
This truck has the gu5 code in the glove box. So according iamkeniff that's 3.23's... I would say that's a fairly significant jump in gear ratio. Had the drive shaft supported by a jack stand when we did the gear swap...stock u-joints. I'm gna have Nelson's Performance in San Antonio build me a drive shaft we I get the extra $$. Until then, just gna have it high speed balanced. Also got Corevette Servo on the way. Anybody have some good advice on best tranny for a future swap?
Old Aug 2, 2012 | 12:14 PM
azchevydude's Avatar
Performabuilt or finish line. Look to the right. I will be getting mine from one of them.
LCHEE
Oct 24, 2020 04:10 PM
V-seriesTech
Jul 28, 2015 12:31 PM
bgray
Jul 23, 2015 10:56 AM
Cowboy Tom
Jul 21, 2015 10:29 PM
GM-only
Jul 19, 2015 10:48 PM
