MY trans went !! Any Idea on Why??
Old Nov 26, 2008 | 10:23 PM
CDN SS's Avatar
Default MY trans went !! Any Idea on Why??
2004 5.3 2wd pcm tune and heaers otherwise stock
Trans started to shift very hard 1-2 for a few days then would not shift just slipped unless I eased up on throttle and let it slide into gear ........fluid clean and up ....... 32 K daily driver not abused tow car trailer 7kgvw in summer never a problem , never overheated ........ this spring had shop install a Transgo HD-2 and vette / sonnex servo's .........
dropped the pan ......some springs from shift kit busted and the plastic pistons broken .....now in shop for rebuild
Hopefully they can give me an idea what caused the failure ....anybody here got any ideas
Old Nov 26, 2008 | 10:28 PM
viciousknid's Avatar
Where's the Beef?
that may be why.
Old Nov 26, 2008 | 10:38 PM
budhayes3's Avatar
PT's Slowest Truck
Maybe the 1-2 accumulator piston let go?
Old Nov 26, 2008 | 10:46 PM
CDN SS's Avatar
Yes it did , I had expected to drop the valve body and replace those parts but apparently the bands etc are used up too ...... could this have been a fualty shift kit install ? when you guys instll shift kits do you replace those plastic pistons with the metal ones ?I dont recall that the shift kit came with replacement pistons
Old Nov 27, 2008 | 07:27 AM
Breeze's Avatar
11 Second Truck Club
That was my thought when I read the first post.
Old Nov 27, 2008 | 09:51 AM
built408's Avatar
Sounds like the 1-2 accumulator piston cracked and burnt up the 2-4 band and drum. I would NEVER install a shift kit and reuse the stock plastic pistons. Always upgrade to the metal ones. It doesn't sound like a faulty shift kit install, it sounds like the piston just cracked and burnt it up.
Old Nov 28, 2008 | 06:19 AM
budhayes3's Avatar
PT's Slowest Truck
There are GM aluminum pistons available as well as aftermarket pinless ones
Old Nov 28, 2008 | 09:40 AM
CDN SS's Avatar
Yes I knew that but did not think to do when only doing a shift kit ..............do most of you install the alum pistons when you do a shift kit for a stock engine daily driver ...........I know the trans shops do when they do a perf rebuild .......or was my experience not the norm and just got unlucky that the plastic ones let go .pbly not but would think would hear more failures after shift kit when plastic pistons left in trans ???
ferrellrooster
Mar 6, 2025 03:22 PM
Blackrat48
Aug 4, 2015 09:52 AM
KyleW707
Jul 29, 2015 08:17 AM
lxcoupe
Jul 14, 2015 10:14 PM
Nimoryan
Jul 5, 2015 03:50 PM
