Is my driveshaft length ok?
Old Feb 25, 2008 | 08:51 PM
chevymanLS2's Avatar
Banned
Default Is my driveshaft length ok?
I have a 2000 4wd silverado 1500. I am in the process of converting to a 4l80E and wanted to know if my driveshaft length is ok. If I unbolt it, there is about 3/4" of play before it hits the t-case. I hope it's not too long. Thanks.
Old Feb 25, 2008 | 09:04 PM
Banned
heres some pics if it helps
Old Feb 28, 2008 | 05:12 PM
Banned
anybody?
Old Feb 28, 2008 | 06:27 PM
ZZebes's Avatar
Way to long
Have it shortened 2-3 inches
Old Feb 28, 2008 | 06:28 PM
adam1803's Avatar
definetly too long, there needs to be a certain amount of slip travel and that aint got it.
Old Feb 28, 2008 | 06:45 PM
stocker's Avatar
there should be 1 inch of slip. those slips are fairly long so 1 1/4 inch will be no problem. you can take it to your local driveline shop with the mearsurement, and they should beable to take care of you. measure seal of tranny not that rubber boot to the center of the rear u-joint(which will be the flats of the pinion yoke).
Old Feb 28, 2008 | 10:16 PM
Banned
****, well is it ok for about 3 days or would it be very stupid to run it as is. It has about 1/2 inch of play in it.
Old Feb 28, 2008 | 10:35 PM
silveradokidd_4518's Avatar
here ya go...
http://speed-eng.com/store/product_i...oducts_id=6634
Old Feb 28, 2008 | 10:53 PM
BlownChevy's Avatar
blownerator
25 Year Member
I would not run it like that. You will be looking for a new transmission tail shaft if you do.
Old Feb 29, 2008 | 07:08 AM
yea, I'd say 1-1.5" shorter. I've seen some bad damage due to a driveshaft like that.
