My 4x4 60e to 80e swap saga
Figured there is alot of 80e questions hopefully this helps someone out
my truck
2005 5.3 4x4 with 58" bed
trans 96 4l80e from a 6.5 diesel
parts used
Circle d converter and flywheel
Rear Drive shaft 65 1/4 length 1 piece alumium, i shortened my stock to those dimensions
Front drive shaft PN 15182094, came from a 04 3500HD pickup
AC delco dipstick tube PN 15832205
Stock 60e dipstick
Bellhousing cover 15765623 got direct from GM
cut my stock X member add a 6 3/4 plate to each side
also had to notch the x member where my tcase motor was as it was hitting
NP246 transfercase used PN 19019 for my 32 spine shaft
Merchant auto pump rub kit while i was there PN 10057
seal kit PN 10064 from merchant automotive
Shifter cable bracket PN 15013290 i tried to use the style that faces outward but would not allow me to manually put my truck into 1st gear
the one i have looks like this
got my 2nd speed sensor with bracket on ebay
4L80E Input Output Speed Sensor 91 Up GM New 4L80 4L80 E | eBay
repinned the plug
https://www.performancetrucks.net/fo...g-swap-413157/
Made my own trans line kit with 3/8 lines and AN fittings with a stock 03 duramax. Bolt in direct fit
https://scontent-b-dfw.xx.fbcdn.net/...61969118_n.jpg
Fittings: russell 640520
Russell 640520 Transmission Line Cooler Adapter Fittings 6 An to 1 4" NPSM | eBay
my truck
parts used
Stock 60e dipstick
repinned the plug
How did you re-program your PCM? I am gathering all the details for a 4L80E swap into my 2006 suburban and I am trying to figure out how difficult is it going to be to re-program my PCM.
Thanks,
-Raj
Thanks,
-Raj
I still cant get my truck manually into first. The bracket I bought was the same one I already had. Ive tried adjusting my cable many times. I had to put a new Neutral Saftey switch on, which tells the trans what gear you are in from what I understand. I think i screwed it up when putting it on by not having it in neutral like it said (whoops). Could this be why i cant get it to stay in first? Sometimes I can jam it down and when I take off its in first but then quickly shifts to 2nd. I cant downshift into first and the cluster rarely will read 1st.
