my 4l80 swap
Old Jun 28, 2013 | 07:43 AM
  #31
slowprocess's Avatar
I'll screenshot the TCC release settings, everything else in my tranny tune is tailored to my setup as the trans is fully built.
I too need this!
Old Jun 28, 2013 | 09:31 PM
  #32
cdub81's Avatar
If you're talking about the TCC releasing on decel then this is what I did to make it stay locked until it reaches my minimum release speed set in other tables. Works flawless and it ill release when I hit brakes and apply when I let off brakes. The 60e would release when I hit brakes and then I had to give a little throttle and It would lock then, It now locks as soon as I release brake as long s I'm above the min VSS release
Old Jun 28, 2013 | 09:36 PM
  #33
03sierraslt's Avatar
Mine has Low speed and High speed at 256 and the rest zero like pictured above. So on that note, it doesnt seem the low and high speed make a difference but rather that the rest is zero'd out.
Old Jun 29, 2013 | 08:38 AM
  #34
My version of Hptuners doesn't have that minimum throttle release column on it. Can't update the software either since I'm using the old school serial cable. Any way I can change this without that column?
Old Jun 29, 2013 | 06:41 PM
  #35
cdub81's Avatar
As far as I know it's in the 2.24v release. My software came with 2.23 and it didn't have that column until I updated on the HP website
Old Jun 29, 2013 | 09:31 PM
  #36
That table is the only way to change it.
Old Jun 29, 2013 | 11:15 PM
  #37
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by slammedsilvy
I now have the Frost harness that doesn't need a speed sensor added though and I'm still stuck in 2nd.
I believe that this is likely the source of your problems. The PCM/TCM needs that input speed sensor information.
Old Jun 30, 2013 | 07:46 AM
  #38
All the harnesses I seen still had that speed sensor hook up. As Roger said, the PCM needs that input. Unless the frost harness is made to operate off of a 60e tune? If that's the case then no segment swap is needed.
Old Jun 30, 2013 | 09:23 AM
  #39
swift700's Avatar
Wiring in the speed sensor is the easiest part of the 80e swap.
Old Jun 30, 2013 | 10:01 AM
  #40
Yes, its very simple.
