Multi Disc Converter Questions
Is use that cam in a 6.0 with some worked heads and roll with it of you're totally against a blower. An lq4 with those 243s you got would give you around 10.4:1 which should be good on 93 and lower timing for towing.
traveling mod
Ok even if i keep it to 2400-2600 single or mulit disc???
Im against spending 10g's to build another motor plus tranny + blower
I really want an ls2 for weight savings but an iron 370 would please me just the same
If you were going to put a blower on it, I'd say triple disk so you can build some boost in od locked up but since you're not I don't see any point in spending the bucks on a triple.
great topic going here guys as i just got my Circle D 2800-3000 multi disc in. I dont know about towing without an upgraded cooler im seeing 185 and 210 temps when getting down on it. I have to tow a 6000lb trailer october 10th and i wont do it the way the temps are now. Im going to switch to AMSOIL tranny fluid for the 6L80E a 6L90E filter and a bigger cooler. As far as lockup goes im going to have to look into that. any input guys? will i need a computer all the time?
We have a new Stage II we are doing. Have not really released any details yet, but we have been working on it for a about a year. Designed it for the 258mm setups. It is still a single disk, but with a lot of clutch area. We get about 50 square inches. It was engineered to take bigger loads while towing. Sounds like it will be perfect for you.
Chris
Chris
Chris
