missing 3rd gear
Old Dec 21, 2010 | 08:05 PM
00yukon22"'s Avatar
Default missing 3rd gear
im lost on this one, reverse, first and second work fine, but when it goes to shift from 2nd to third the rpm's shoot right up and it wont catch. my tow and haul had stopped working a few months back, and my torque converter bolts had backed out and hit the cover over the rear main seal, so i had to pull the tranny and get the broken bolts out and replace the rear main seal and cover, i dont know if i could have damaged something in the process. after fixing the converter it worked fine for about 10k miles. where do i start?
00 gmc yukon, 5.3l 4wd. any help would be greatly appreciated
Old Dec 21, 2010 | 08:11 PM
viciousknid's Avatar
Where's the Beef?
Could be clutches or a shift solenoid perhaps?
Old Dec 22, 2010 | 05:16 AM
Vince B's Avatar
Sounds like your 3-4 clutch has failed in your unit. Its probably the #1 failure in these units from my experience. With that being said its time to have it repaired or replaced. Vince
Old Dec 30, 2010 | 04:06 PM
00yukon22"'s Avatar
where can i find a replacement clutch, and solenoid, and how hard is it going to be to be replaced. am i better off getting a diff. tranny?
Old Dec 31, 2010 | 10:55 AM
Where's the Beef?
the shift solenoid is easy as dropping the pan as far as i know.
Clutches require the transmission to be completely gone through. Odds are that when your converter bolts backed out it messed up your pump and you didn't get sufficient pressure when shifting and burned up the clutches.
Old Jan 12, 2011 | 08:14 PM
00yukon22"'s Avatar
i need to get this going asap, ive been trying to find a replacement tranny for a decent price with no luck. anyone have any ideas on where to find one in ma, or a good shop to have mine fixed at?
Old Jan 17, 2011 | 07:41 AM
Killtank's Avatar
I had the exact same thing happen to me. Took it to my buddy and he said for some odd reason the clutch was nearly destroyed. Said it may have gripped for the 2nd gear but not for 3rd. I don't know much about transmissions but he said it was really rare. I think I remember him saying something about more pressure being applied during the 1-2 shift and the the 2-3 had too much torque for the broken clutch to grasp. Good luck and hopefully its an easy fix. If you are gunna rebuild I suggest you beef it up so it is less likely to happen again.
ferrellrooster
Mar 6, 2025 03:22 PM
Oobray
Jun 13, 2022 03:38 AM
TimDave217
Aug 24, 2015 04:38 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
GMCtrk
Jul 17, 2015 06:39 PM
