Mcgaughy's helper bag kit?
Old Jun 26, 2012 | 04:08 PM
02gmcbandit's Avatar
Default Mcgaughy's helper bag kit?
well my kit finally came in and I got to thinking. which would be the best way to mount it?? in the front or the rear? I didn't buy it for the towing, just the ride quality and to hopefully help with wheel hop.
If I install it in the front shouldn't that cure my wheel hop?? or should I put it in the rear?? I want to help the ride most of all, I can get traction bars for the wheel hop but was wanting to kill two birds with one stone
Old Jun 26, 2012 | 04:12 PM
jvoisel's Avatar
In the rear.. That's what it's designed for. Do you have a mcgaughy's notch? It will bolt right up to the rear 4 bolts.
Old Jun 26, 2012 | 05:19 PM
no I have the DJM flip kit with c-notch, just by looks at it everything should like up, if not I work at a shop when I can make new plates and brackets if need be. just trying to decide where to mount everything before I tear my truck apart
Old Jun 26, 2012 | 06:50 PM
TXsilverado's Avatar
i welded my bag kit to the DJM notch. eazy peezy.
Old Jun 26, 2012 | 10:12 PM
Where did you mount the filler fitting to put air in the bags at? I'm thinking maybe inside by the gas cap but not sure. I dont want to put it by the tag like I've saw done. Want it hidden
Old Jun 27, 2012 | 03:09 PM
.James.'s Avatar
I currently have mine like Jvoisel stated, in the rear. No welding or anything either, as I purchased a mcgaughys notch, which means the helpers come with a bracket to bolt right up, and I also ran my line to the gas tank. Much easier, and it's hidden.
Old Jun 27, 2012 | 09:32 PM
well, as my luck always goes, the bolt holes for the C-notch and the bag bracket do not line up.not even close, so I have to drill new holes on the bag bracket. no big deal but it set me back from installing it today.
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Nov 5, 2015 06:49 AM
livefast1
Sep 25, 2015 07:31 PM
LARRY01Z28
Sep 16, 2015 10:02 PM
ksbrktracer
Aug 24, 2015 10:55 PM
