Mcgaughy's helper bag kit?
well my kit finally came in and I got to thinking. which would be the best way to mount it?? in the front or the rear? I didn't buy it for the towing, just the ride quality and to hopefully help with wheel hop.
If I install it in the front shouldn't that cure my wheel hop?? or should I put it in the rear?? I want to help the ride most of all, I can get traction bars for the wheel hop but was wanting to kill two birds with one stone
no I have the DJM flip kit with c-notch, just by looks at it everything should like up, if not I work at a shop when I can make new plates and brackets if need be. just trying to decide where to mount everything before I tear my truck apart
Where did you mount the filler fitting to put air in the bags at? I'm thinking maybe inside by the gas cap but not sure. I dont want to put it by the tag like I've saw done. Want it hidden
I currently have mine like Jvoisel stated, in the rear. No welding or anything either, as I purchased a mcgaughys notch, which means the helpers come with a bracket to bolt right up, and I also ran my line to the gas tank. Much easier, and it's hidden.
well, as my luck always goes, the bolt holes for the C-notch and the bag bracket do not line up.not even close, so I have to drill new holes on the bag bracket. no big deal but it set me back from installing it today.
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Nov 5, 2015 06:49 AM
LARRY01Z28
Sep 16, 2015 10:02 PM
02, air, bag, bags, f150, helper, installation, installing, instructions, kit, leaks, mcgaughy, mcgaughys, review, shocks
