Mcgaughy 2/4 vibration problem.
Old Feb 22, 2011 | 04:52 PM
7firebird1's Avatar
Default Mcgaughy 2/4 vibration problem.
Hello all, I have a 2000 Silverado 2wd that was lowered with Mcgaughy's 2/4 drop kit with spindles, shackles and hangers. I have a vibration under hard acceleration and between 15 and 20 mph. Anyone else have this issue? Any suggestions? Thanks.
Old Feb 22, 2011 | 05:13 PM
Static54's Avatar
Check the Pinion angle?
Old Feb 22, 2011 | 05:24 PM
7firebird1's Avatar
Have not checked that. Not to sound like a goober, but whats the best way to check that and what degree am I looking to be at? Thanks
Old Feb 22, 2011 | 08:22 PM
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
Yep, you're pinion angle is off. I'm 4/6 on a torsion bar set up(read: up higher from the factory than coil spring suspension so probably more like a 5/7) & my pinion angle is pointed up 8-10 degrees. I rode with it like that for a year. I just ordered some 6 degree shims today & hope this will get it close enough.
Here's an article to get you started.
http://www.carcraft.com/howto/91758/index.html
Just google "how to set pinion angle"
Old Feb 22, 2011 | 09:44 PM
badz24s's Avatar
Here's another good article:
http://www.airridetalk.com/articles/...-enigma_2.html
Old Feb 22, 2011 | 09:46 PM
grey matter 04's Avatar
13 Second Truck Club
if your an xcab you probly need the carrier bearing spacer kit to correct the pinion angle
Old Feb 23, 2011 | 05:58 PM
7firebird1's Avatar
It is an extra cab. I will try the spacers and check the pinion angle. Thanks for all the help guys.
walledition
Feb 24, 2026 03:27 PM
REDCYCLE13
Sep 15, 2016 03:02 PM
06droppedcrew
Nov 17, 2015 10:56 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
twake_410
Sep 25, 2015 10:09 PM
