man , a little help please ( more bad luck for muah)
Old Jan 19, 2008 | 03:20 AM
2004SSS's Avatar
dewey what was your symptoms?
shannon i need someone who can come look at it where it is, right now im hoping it may just be the flexplate but i know my lucj better. i need someone to come mic it and make sure everything is lined up , if not the motor must come out.
Old Jan 19, 2008 | 07:29 AM
dewmanshu's Avatar
Moderately Differentiated
I doubt it is a thrust bearing, I was just noting the history of mine. If your crank is moving so is the alignment on the sensor. I don't know how much you have been driving it, but the tune will be waaaay off on one day and spot on the next day. (crank sensor)
Get that tranny out and find out what really is broken. Start with what is broken first before ya troubleshoot too much and get too scared. If you have a trans pump out, make sure the clearances are good and if so have an engine shop look at your flywheel (easy enough to take measurements all the way around it to see if it clears the same). Yes it would be cheaper to just replace it, but more expensive if it turned out not to be the actual problem. I am sure it's something sorta simple, but you're gonna need a pro to map it all out if this is really a reoccurring issue.
Old Jan 19, 2008 | 10:15 AM
CHEVRACER83's Avatar
DAMN SORRY CHASE... IF YOU CANT FIGURE IT OUT LEMME KNOW AND ILL SEE IF MY GUY CAN MAKE A HOUSE CALL
Old Jan 19, 2008 | 08:41 PM
2004SSS's Avatar
dewey , man i hope your right. i really hope its a flywheel and converter that would save me alot of time , money and stress.
i doubt its a crank problem too but im not ruling it out. my tune isnt much different from day to day , when i dropped this motor every sensor was replaced.
holty whats your email addy?
shannon yes i may need him too , the main thing i need to check now is my flywheel and my converter clearance. give me a call or pm so we can set this up if your guy can check out both of these problems.
Old Jan 20, 2008 | 12:44 AM
ill call you as soon as i run it by him... wheres the truck out now??
Old Jan 20, 2008 | 08:45 AM
Eye-P's Avatar
Toy shop in Pomona is your best bet for getting this figured out locally.
Old Jan 21, 2008 | 08:48 PM
2004SSS's Avatar
the truck is already at the toy shop , they have built this thing 4 times now. first time it lasted for over a year. now i can get it to last longer than 3 months.
Old Jan 23, 2008 | 07:48 PM
2004SSS's Avatar
well the tune is pretty much ruled out, and im think im going to switch converters back and replace my fly wheel.
Old Jan 23, 2008 | 08:35 PM
Wilde Racing's Avatar
How do I change this text
damn, dude THAT SUCK, I hope the new flex plate and vert fixxes it.....
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
Wolftrk99
Oct 2, 2015 08:17 AM
trxmxzx
Sep 29, 2015 07:42 AM
