LS1 Stall in my truck. Will it work?
Old Nov 9, 2006 | 12:08 PM
RandomHero's Avatar
Default LS1 Stall in my truck. Will it work?
Ok, first of all I spend a good 30 minutes searching for this and found 1 thread, which only a couple people said it would work, but I found a 2600 stall converter for an ls1. I've heard it will work and it will stall higher in a silverado. Here's the quick questions
Will it work in my 4l60e?
How high should I expect it to stall if it stalls to 2600 in a camaro?
EDIT-it's a stealth thruster 2600 if that makes a difference.
Old Nov 9, 2006 | 12:09 PM
TXsilverado's Avatar
seems like it would stall higher in a camaro because they have more torque
Old Nov 9, 2006 | 12:11 PM
RandomHero's Avatar
I am by no means saying your wrong, BUT from what i've read, people have said it stalls higher in a heavier silverado.
Old Nov 9, 2006 | 12:21 PM
torque converters work off of the torque of a motor, not the weight.
can you post some links to these threads your talking about?
Old Nov 9, 2006 | 12:22 PM
RandomHero's Avatar
hold on let me try and find it again. Like I said it took a while to find one
Old Nov 9, 2006 | 12:30 PM
RandomHero's Avatar
here's one. I'm working on finding more still
https://www.performancetrucks.net/fo...aro+stall+work
Old Nov 9, 2006 | 03:23 PM
Quik's Avatar
5 year bitches!
i run a 3500 car converter that stalls to 3800 in my truck
Old Nov 9, 2006 | 03:31 PM
RandomHero's Avatar
is it out of an LS1? I want to be absolutely sure it will work before I buy it.
So i take it a 2600 stall would stall up to around 2800 in my truck?
Also, would it feel looser or tighter in a truck?
Old Nov 9, 2006 | 03:35 PM
yeah, but arent you on a 408? i'd say that would push just a tad more torque than the ls1
Old Nov 9, 2006 | 03:50 PM
RandomHero's Avatar
damn that's true.
It might not be bad though since right now i won't need more than a 2600 stall and I guess once I do the 6.0 with tr224 or similar swap I'd have a little more torque to make it stall higher. I know i'll never want bigger than a 3000 stall since it's my daily drive and 99% of it's miles are highway.
