LQ9 and Turbo 400
Old Mar 26, 2007 | 05:44 PM
Default LQ9 and Turbo 400
Well I am ditching the bbc in my 72 blazer and going with a LQ9. What all will I need to make the th 400 bolt up. I already have a new 2500 stall, will it work?
Thanks, Kade
Old Mar 27, 2007 | 09:33 AM
vanillagorilla's Avatar
If you have a converter for a TH400, then yes it will work. You'll need a flexplate for a Gen III engine from either TCI or ATI, and it'll come with a spacer. Put the spacer right on the crank and then the flexplate on the that. It spaces the flexplate out enough so it mates with the standard TH350/400 converter. You'll only use 5 bolts to bolt the engine and tranny together. Your driveshaft may have to be modifed given where you place the engine, and the same goes for your cross member.
Rafe19
Oct 18, 2016 12:27 AM
06 4.8
Aug 16, 2015 06:16 PM
Sierra1320
Aug 15, 2015 08:04 PM
The_W
Aug 15, 2015 08:07 AM
