Lowing BASICS PLS???
Old Jun 1, 2009 | 07:00 AM
dhpro's Avatar
Default Lowing BASICS PLS???
All I want to do is drop my rr end 2" to level out the ride:
1. how will this effect the pinion angle and how can it be fixed?
2. whats the simplest way to drop the rr by 2" and retain travel and towing?
Thnx guys! R/
Old Jun 1, 2009 | 07:42 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
remove lift blocks and get standard 2wd u bolts. Cheap and effective. Pinion angle might need shimming maybe 2*. It's done wit a small wedge called a shim. Easy job.
Old Jun 1, 2009 | 10:03 AM
dhpro's Avatar
Thnx Trev! Where can I get the shims, and where do they go?
Old Jun 1, 2009 | 10:12 AM
JoeGibbSilverado's Avatar
summit sells them, also a local 4x4 shop will have them, they are pretty cheap, they go between your rearend and leafsprings ,
Old Jun 1, 2009 | 10:21 AM
dhpro's Avatar
Thnx! R/
calsdad
Jun 14, 2023 11:07 PM
thewrx
Oct 6, 2015 10:59 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Rockrz
Sep 29, 2015 09:07 AM
trevorh1
Sep 27, 2015 08:47 PM
