Lowering experts look inside..
Old Jun 28, 2011 | 12:29 PM
gnd111's Avatar
Default Lowering experts look inside..
My truck is lowered 4/6 (DJM LCA's and shocks) anyways it bounces like hell and has some bump steer to it.
How can i stiffen up the front? can i get the shocks specified for a 2" front drop?
Can i get different springs to stiffen it up? DJM website is difficult to navigate and get answers to questions and i can't find a phone number for technical help.
Any ideas? Thanks..
Old Jun 28, 2011 | 01:09 PM
lowoh8's Avatar
get rid of the arms and go springs and spindles
Old Jun 28, 2011 | 02:09 PM
low2001gmc's Avatar
give me a call. i got djm on both my 01 gmc and 08 silverado with no issues whatsoever or complaints. laterz, rob (956) 802-7700.
Old Jun 28, 2011 | 03:59 PM
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
I've got spindles & mine does the same thing
Old Jun 28, 2011 | 10:40 PM
low2001gmc's Avatar
GND111 ALREADY REPORTED BACK CONFIRMING WHAT WAS MY SUSPICION.
MOST COMMON MISTAKES ON DROPS AND EXPERIENCING ROUGH RIDES AFTERWARDS IS REMOVAL OF FRONT OEM BUMP STOPS AND REPLACEMENT OF REAR BUMPSTOPS.
USUALLY ITS THAT FRONT BUMP STOP KIND OF TRIANGULAR SHAPED EASILY SEEN WHEN YOU TURN WHEELS INWARD AND LOCATED AROUND THE SPRING AND SHOCK AREA. YOU CANT MISS IT. IF YOU DONT REMOVE IT, WITH THE SUSPENSION NOW LOWERED, THERE IS LIMITED CLEARANCE BETWEEN BUMP STOP AND METAL LIMITING SUSPENSION TRAVEL AND CAUSING IT TO HIT BANG HARD ON BUMPY ROAD CONDITIONS. REMOVE IT AND NOW THE SUSPENSION IS FREE TO MOVE WITH THE ROAD CONDITIONS AND ALLOWS THE SHOCK TO ADJUST AS IT SHOULD. THE BUMP STOP ONLY HAS ONLY ONE BOLT AND NUT. QUICK AND EASY REMOVAL. HOPE THIS HELPS OTHERS AS WELL.
Old Jun 29, 2011 | 05:58 AM
gnd111's Avatar
The front bump stop hangs down pretty far (at least 1.5") so it was definately causing the bounce problem. Truck is much smoother now.
Thanks low 2001 gmc!
hodge9386
Oct 25, 2015 01:26 PM
Miguel199
Oct 16, 2015 08:04 PM
BCraven1018
Oct 1, 2015 08:22 PM
X_Racing1
Sep 30, 2015 01:59 AM
vmaxpro
Sep 28, 2015 11:10 AM
