lowering 04 tahoe?
Old Nov 23, 2008 | 10:42 PM
2001CamaroGuy's Avatar
Default lowering 04 tahoe?
Just bought a 2004, 2WD, 5.3Liter Tahoe today (YAYYYYYY!!!!!!)
I wondering how I go about lowering/adjusting the front end since I noticed it is a torsion bar setup vs. coil springs (never worked with them before).
Are the spindles on a Tahoe the same as on a Silverado? Reason I ask is that I did the 2" drop spindles on my Silverado, loved the results, and would like to do the same on this vehicle.
Old Nov 25, 2008 | 06:08 PM
supercharged tahoe ss's Avatar
Follow the torsion bar to the end and you will see a bolt under it tighten that bolt and the truck ill lower take it for a ride around the block use a measuring tape and measure from the ground to fender on both sides if its the same leave it if not loosing the side that is lower to raise it up to match other side. if it not low enough for you, you must go and buy the torsion lowing keys. the bolts that you tighten are almost right in the middle of your drivers door under truck about 3 feet apart i think it is a 15 or 17 mm for the back if you have air ride you have to get shock extenders and lowering springs. i just bought the ground force kit it come with everything you need. dont forget once you touch those bolts you need an alignment.
Old Feb 2, 2009 | 10:09 AM
BLWN1's Avatar
I lowered mine 3/5 inches. I wouldnt do any different, just had to cut the bump stops a few times to get it right. I can get pics later, I have 20s wish I had 22s..
BCraven1018
Nov 2, 2015 07:18 AM
mitchellmade
Sep 27, 2015 08:27 PM
project-pegasus
Sep 18, 2015 08:22 PM
b4z
Sep 10, 2015 06:58 PM
xerox17
Sep 5, 2015 01:23 PM
