Lowered rcsb 4x4
Old Feb 3, 2016 | 09:19 PM
Rrodriguez13's Avatar
Default Lowered rcsb 4x4
Hello i have an 06 silverado 4x4 and i dont really use the 4wd so i decranked the keys and used 2" lowering shakles but i want to go a little lower in the back. I want to know how much more can i lower my truck without a cnotch
Old Feb 3, 2016 | 09:28 PM
FFDP's Avatar
Another 2in is fine without a notch, then you get pretty darn close to the bump stops. You can cut them too, to give more room.
4x4 should have a lift block, remove that and it's about 1in drop for free.
Old Feb 3, 2016 | 09:35 PM
I actually already removed them sorry i forgot to include that in the post.. So that means i can safely lower just about 1 more inch since i already removed the blocks??
Old Feb 3, 2016 | 09:59 PM
FFDP's Avatar
I'd stick your head under the truck and see how far you are away from the bump stop currently.
Figure you can likely only go another 1-2in in the rear before it has a real chance of bottoming out on you. And you won't be able to load much in the bed once you get closer. Also going any lower than what you have done will need drop shocks in the rear. And the pinion angle will change for sure if you go lower, so you'll have to measure that and correct it as needed.
Old Feb 3, 2016 | 10:01 PM
mikeyjm1's Avatar
you can probably go lower still in the front too. They'll go pretty far before the CV angles are bad and even then you can use a spindle.
Old Feb 4, 2016 | 12:51 PM
TrevorH's Avatar
On a 4x4, the bumpstops in the rear are on a bracket. You can remove the brackets and bolt the stops directly to the frame.
Old Feb 4, 2016 | 02:00 PM
mikeyjm1's Avatar
like Trevor said,
if its like the SUV's cut the mounting cup off, smooth it flat, and drill and tap hole in the center for an Energy Suspension pancake style (about 3/4" thick) bump stop.
jrs01
Feb 3, 2016 04:52 PM
Joevc
Feb 3, 2016 10:00 AM
fillpot
Feb 1, 2016 10:04 PM
rijrunr
Jan 30, 2016 10:05 AM
