lower and load springs
Old Feb 11, 2009 | 08:13 PM
2.6KB's Avatar
Default lower and load springs
I'm looking in to buying belltech 2"drop spindle and 2"shackles but want a little more in the rear. I have cal-tracs all ready I have read you have to modify the 2" drop hanger to keep my cal-tracs. So i was thinking for removing my load spring to get a litte more. What would be the pros and cons of the load spring. I would like to see pics of the hanger modify if someone has any.
Old Feb 12, 2009 | 04:33 PM
LoweredZ71's Avatar
Buy the mcgaughey's spindles cheaper and better product
Old Feb 12, 2009 | 09:34 PM
fredkj3's Avatar
get the hotchkis leafs.. thats the set up i have... hotchkis 4 " leafs... 2" shackles and caltracs.... only thing is that you have to put the aluminum bushings on a lathe to fit in the hotchkis leafs..
i love this setup
Old Feb 12, 2009 | 10:21 PM
BigCountryx's Avatar
I'm gonna do the same (remove the overload) once I get my longbars. No con other than loosing payload capacity.
Old Feb 13, 2009 | 01:52 AM
95 bright teal's Avatar
Removing the overload will get you close to one more inch of drop, and the disadvantage to doing it, is axel wrap. but you have caltracs already so it wont be an issue.
from what i hear it will ride smoother and your getting rid of a decent amount of weight
Old Feb 13, 2009 | 08:43 AM
2.6KB's Avatar
I did a bunch of searchs and found a pic of bluecajun5.3 cut belltech hangers. I thank i"m going do the 2/4 and take out the load springs and use keys for a 3/5. Thanks for the feed back. Now what shocks to run.
Old Feb 13, 2009 | 09:12 AM
LoweredZ71's Avatar
I still think it would be a better route to use the spindles and decrank just a inch or so and remove the overload spring and use shackles for about a 3/3
Zizzle
Oct 19, 2017 08:44 PM
GXPJAY
Nov 5, 2015 06:49 AM
BigEd_72455
Aug 8, 2015 04:49 PM
Slammed96
Jul 27, 2015 07:22 AM
