Loud Clicking From Drivetrain
Old Feb 4, 2008 | 01:10 PM
  #21
Last Call's Avatar
TOTM: January 2007
Originally Posted by viciousknid
same here.. the driveshaft usually goes first.
I'll have to ask danny what my shift points are set at, but mine sees probably 6300 or so on a daily basis. and anywhere from 105-120 about 3 to 5 times a week.
I like the way you drive.. LOL
A good safety measure would be to have the driveshaft high speed balanced. The factory did not install my rear u-joint perfectly from the factory.
Old Feb 5, 2008 | 11:02 PM
  #22
Blown02Sierra's Avatar
what would be a good brand to go to? It looks like a little bit of grease came out of my caps on my rear u-joint and I have a sketchy clicking noise from the rear. Should I go to the stealership and get ripped off? I don't really want to trust the autozone generic brand.
Old Feb 7, 2008 | 12:24 AM
  #23
Well I changed my ujoints to the greasable kind (all I could find). Upon removing the caps on the front u-joint I found no grease. Upon removing the caps on the rear u-joint, rust and dirt came out lol. A chunk was missing from one of the caps. I definitely should have replaced them sooner. I've heard bad things about the greasable ones, but I heard that they go bad only if you use regular grease instead of lithium high pressure grease so that's what I used and will use.
dsbodley
Nov 14, 2015 09:46 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
Rockrz
Sep 29, 2015 09:07 AM
lycominghunter
26
Sep 25, 2015 07:50 AM
