Lost Overdrive
Old Aug 12, 2008 | 06:55 PM
Gordy M's Avatar
Default Lost Overdrive
I have been towing a 7800 lb enclosed trailer for several years w/Escalade ESV. Lately OD would occasionally slip, came home Sunday pm w/o any problem and dropped off trailer. Went to use it today (w/o trailer) and no OD. Ran a scan log and it would not shift into 4, and no VSS speed. The speedometer works correctly and 1, 2 & 3 work fine. Is it just the VSS, fluid, 3/4 clutch pack or ?
Old Aug 12, 2008 | 07:23 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Check connector on VSS first (passenger side of tailhousing). Or... Maybe the little screw/bolt that holds the sensor in place isn't securing the VSS. W/O the VSS, the trans' shifts won't be as accurate as normal parameters would.
Old Aug 18, 2008 | 07:19 AM
Gordy M's Avatar
Finally got around to changing the sensor. That did the trick...thanks for your help.
Old Aug 18, 2008 | 11:26 AM
95ImpSS's Avatar
SloSVO
Nov 22, 2020 07:34 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
LT-1 SS
Sep 26, 2015 05:19 AM
fortune46x
Sep 16, 2015 08:18 AM
