lets talk locking & limited slip rearends................G80 is toast
Old May 16, 2005 | 02:07 PM
  #41
moregrip's Avatar
what a rush!
Originally Posted by BMDMAX
I second the bearings and races. I did re-use my ring gear bolts since they are not a TTY and I did not feel like tracking a new set down. No problems with that tactic yet.
Not to beat a dead horse but did ya call who I suggested? Might be higher but they were the cheapest I found for what I needed.
not yet, still at work(military), waiting till there's less brass around or until I get home, but I will call.
Old May 16, 2005 | 02:16 PM
  #42
BlownChevy's Avatar
blownerator
25 Year Member
Waiting on that info we talked about.....I should have an answer soon.
Old May 16, 2005 | 02:55 PM
  #43
moregrip's Avatar
what a rush!
cool, I'll be home in an hour or so
Old May 16, 2005 | 07:23 PM
  #44
02_2500avalanche's Avatar
**** spending $300 just for the carrier, thats bs. Im gonna search around tonight to see what I can find. I wonder if the older 14 bolts use the same carrier as the AAM 10.5" 14 bolt because then we could just go to the junk yard and snag them for cheap, its not like it is that much of a wear item.
Alex
Old May 16, 2005 | 07:41 PM
  #45
14 Second Truck Club
Alex
They interchange. So if you are doing a Detroit you can use the older style case. The 6258336 is the old style part number.
Old May 16, 2005 | 08:32 PM
  #46
moregrip's Avatar
what a rush!
final decision made, going with the detroit locker, will order it from dts if I can't find it cheaper than $354 elsewhere.
thanks for all the advices and help, you guys rock!
Old May 16, 2005 | 10:22 PM
  #47
1SlowHoe's Avatar
Destroyer of Transmissions
Do the names Mosier or a brut strength ring a bell with anyone? Heard they were good as well.
Old May 16, 2005 | 11:25 PM
  #48
The Brute strength diff is basically the same as a Eaton limited slip.
Old May 16, 2005 | 11:34 PM
  #49
black4x4's Avatar
just buy a master install kit for your rear and it should have everything in it need to rebuild your rear. and good chioce on the detriot. and don't worry about long rode trips mine makes no niose just going down the highway, just a little in town around corners.
Old May 16, 2005 | 11:54 PM
  #50
moregrip's Avatar
what a rush!
thanks man, I've been reading more about the detroit and from what I can tell most say they are not as bad as they use to be.
