just installed 2/4 drop on silverado w/22's
Old Dec 4, 2005 | 12:28 AM
silverado22's Avatar
Default just installed 2/4 drop on silverado w/22's
I installed a 2/4 drop on a 05 silverado ecsb with stock shocks. I have 22's with a tire size of 305/40/22. I am having a problem with my front end bottom out on my fender well. What kinda shocks are recomended for a stiffer ride so this does not happen?
Old Dec 4, 2005 | 06:59 AM
tdrumm's Avatar
Bilstein, Edelbrock are two. Stiffer shocks will help a little, but aren't the real solution. Ride height and suspension travel are still the same, so the potential to rub will always be there.
There have been a few guys who run 305/40/22s on a 2" front drop without rubbing. Do you know the backspacing on your wheels? That may be your real problem.
Old Dec 4, 2005 | 11:54 AM
Mort's Avatar
Cool
How about stiffer bump stops? Just make it ride like poop? Stiffer shocks may make it handle a little better but your ride will be stiffer as well and they will not limit your suspension travel.
Changing your wheel offset may be your best choice to eliminate your rubbing problem.
Old Dec 5, 2005 | 12:37 AM
NeverSatisfied02's Avatar
Damn!! If you rub with a 2/4 and 22's, ill be rubbin for sure! Im about to do a 4/6 on 22's with 265/40/22 tires. My tires will be shorter but my drop will also be 2" lower so it will be worse! Not looking forward to that! lol
I would say backspacing is your issue. My wheels have 5.5" backspacing and they are 22x9 centerlines. I would have liked to go with something with a little more backspacing but as long as they are 5.5" or more, you should be ok with just a new set of shocks and maybe a smaller tire.
Old Dec 5, 2005 | 03:23 AM
ap2002's Avatar
I got some 1" drop coils for sale??? do ya'll think this will help??
Old Dec 6, 2005 | 06:58 PM
TWANKYDEUCE's Avatar
I used to have a 2/4 and 305/40 22 tires and it rubbed all the time even with DT shocks. So I just trimmed out the front fender well and it never hit again. Also, my backspacing was horrible, 5.7" bs on a 9.5" wide rim. so just do that and you will be fine.
oh ya, Neversatisfied, you should be cool with 265/40 22s. I have 265/35 22 and a 4/6 and its perfect, so you may have to roll a little fender lip and trim up some and you will be fine
GMCSIERRA5.3
Aug 7, 2015 01:50 AM
Slammed96
Jul 27, 2015 07:22 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
KleanKustoms
Jul 18, 2015 10:08 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
