Just finished my 6.0 swap, got an SES Automatic Transmission
Old Sep 16, 2005 | 08:51 AM
RangerTJ's Avatar
Default Just finished my 6.0 swap, got an SES Automatic Transmission
Well, I finished the swap last night and all went pretty good after I worked out the Crank issues. I ended up going with the Fuddle HP 2,400 Stall. Anyhow, the SES light came on, so I went to Advanced and had the codes read. It's a code for the Automatic Transmission. Could my stall be the cause of this?
Thanks,
Will
Old Sep 16, 2005 | 09:15 AM
Thanks,
Will
It would help to know the exact code. There are many different codes which relate to the automatic transmission.
Old Sep 16, 2005 | 09:53 AM
RangerTJ's Avatar
All the print out says is P1870, Manfacurer Contrl. Transmission.
Will
Old Sep 16, 2005 | 10:15 AM
P1780 Transmission Control Switch circuit is out of Self-Test Range.
Old Sep 16, 2005 | 03:19 PM
BigBlockChev572's Avatar
Also with a stall, the Shift solenoid code will pop up frequently and the converter wont lock and the truck will be sluggish. That's when I disconnect the battery and it will reset the code (but the SES light is still present, but goes away after awhile)
Philip S.
Old Sep 16, 2005 | 06:53 PM
gonzo 6.2's Avatar
A loose converter can set a slip code, your tuner needs to know what codes to turn off.It will take care of it if that is what your problem is.What did you do about the converter spacing?Did you have a 99-00 6.0 with the longer crank?
Oobray
Jun 13, 2022 03:38 AM
Jake75
Jul 22, 2015 09:20 PM
Cowboy17
Jul 9, 2015 06:18 PM
Aboss
Jul 9, 2015 10:28 AM
davis28905
Jul 8, 2015 03:20 AM
