Just Bought An Auburn Posi Unit... Where can I find an install kit?
Old Jan 28, 2007 | 03:03 PM
benvortec's Avatar
Default Just Bought An Auburn Posi Unit... Where can I find an install kit?
I just bought an Auburn posi unit used, with low miles. It is however for an 98- model and won't fit my 1999. It is still a 8.5 30 spline, so as far as I can gather all I need to do is order a set of carrier bearings that fit the 99+ and install them on the Auburn diff, is this correct? If so, I have a few questions, are Timken bearings the best to use? Also, do the bearings only fit one brand; meaning do i have to buy a certain set of bearings to fit it because it's an Auburn? Does anyone have the part number for the bearings I need? I will also be installing 4.10's so would it be better to just get this all in one kit?
Old Jan 28, 2007 | 03:44 PM
Colby 04's Avatar
I'm using Federal Mogal bearings.
Oreilly's had one bearing and one race, they can order the other and have it the same day.
bearing - LM603049
race- LM603012
Old Jan 29, 2007 | 08:59 AM
benvortec's Avatar
bearing - LM603049
race- LM603012
and this will fit my 1999 2wd correct?
Old Jan 29, 2007 | 09:59 AM
Colby 04's Avatar
That should fit your 99 10 bolt rear carrier. 99+ had larger carrier bearings, those part numbers are for the larger ones - trust me I just bought my second set this weekend.
Choda
Jan 22, 2026 02:03 PM
04450r
Jul 24, 2015 01:58 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
