JL4 EBCM Routing Diagram ABS Brake Module for Escalade Yukon Denali Tahoe Etc
Old Oct 14, 2013 | 09:46 AM
MASS seller approved
Default JL4 EBCM Routing Diagram ABS Brake Module for Escalade Yukon Denali Tahoe Etc
I spent most of my weekend looking for this info so I wanted to repost it here in case anyone else ever needs it, hopefully it's easier to find. This is NOT available in any of the GM service manuals or thru GM at all from what I could find. I found lots of info on the 5 port ABS module, but nothing on the 6 port module. The module itself is not labeled either.
If you ever replace the ABS module (EBCM) or replace brake lines and need the routing diagram for the 6 ports/outlets (RPO Code JL4 Active Handling), here it is:
Looking at the ports face on:
Top row (Left Front)-(Right Front)-(Left Rear)-(Right Rear)
Bottom row (Front Master Cyl (primary), closest to Power Brake Booster)-(Rear Master Cyl)
I finally found the above info here: 2005 Yukon XL brake line diagram to ehcu - GMC Forums
Old Apr 9, 2021 | 07:47 AM
mrtmeo's Avatar
Registered User
Default GM ABS routing diagram
Bottom row (Front Master Cyl)-(Rear Master Cyl)
I believe you have the last 2 ports reversed.
* Front brakes (primary)(2) rear of master cylinder or proportioning valve.
* Rear brakes (secondary)(1) front of master cylinder or proportioning valve.
Rear brakes are normally fed from the front of the master cylinder
Can anyone make this anymore confusing?
Attached is a diagram.
Attached Thumbnails JL4 EBCM Routing Diagram ABS Brake Module for Escalade Yukon Denali Tahoe Etc-abs2.png
File Type: pdf
Old Jun 3, 2021 | 11:36 AM
When I labeled it Front Master Cylinder, I would consider that the closest to the power brake booster. Probably should have labeled it Front Brakes or Primary as the service manual does. I"ll edit the post.
Old Nov 6, 2022 | 12:52 PM
mwallen13's Avatar
Registered User
im a little late to the game here. I, too, just went through finding the correct 6-port BPMV. I finally have one, however, i stripped the port of the last one i had. Does anyone know the port thread sizes?
Hillbilly Silverado
19
Nov 28, 2016 04:51 PM
geoffmt
Dec 15, 2015 11:58 AM
VandykeT/A
Dec 12, 2013 06:19 AM
BillCsCuz
Aug 16, 2012 09:50 PM
CHarris
May 11, 2005 11:04 PM
