Installing a Turbo400 in a 01 silverado HELP!
Old Sep 18, 2011 | 03:52 PM
JoeGibbSilverado's Avatar
i got a good stall for one....
Old Sep 18, 2011 | 04:57 PM
1989k1500's Avatar
Originally Posted by jasond26
my street tire is right at 31 I think. 295/35 22
Should be ~30.1
Old Oct 22, 2011 | 10:58 AM
Half-bred's Avatar
Thanks Jason did you try to used the column shifter or did you go with the rachet, I was able to fab up some brackerery for the stock cable but I think the spread between the gears might be alittle diff, I got the tranny in but the converter is way to high for my dailt driver, as for the speed sensor where is the write up on the conversion I would like to find out about the wires I had to take the control off the side of the 4l60e and plug the wires but in so I could drive it home.
Old Sep 8, 2017 | 03:07 AM
Christy80's Avatar
Registered User
Default 03 2500hd 4×4
Help!!!!!!! 2003 Silverado 2500hd 4×4 6.0L with 4l80e transmission just had our 3rd tranny go out so I wanted to know if the turbo 400 will bolt up to the transfer case or what parts are needed to do so...
Old Feb 18, 2018 | 08:54 PM
Go5.3tt06's Avatar
Since i read here. Anyone can hhelp me. My current 80e crossmember build by here i forget his name that he built crossmember. Will fit Th400? How can i hook up safety neutral switch for reverse light. What about vss sensors??
Old Feb 18, 2018 | 09:32 PM
FFDP's Avatar
This should answer a question of yours.
You can think of this trans as basically a TH400 with a 25 percent overdrive tacked on. The 4L80E transmission was mostly used in 3⁄4- and 1-ton trucks and larger SUV applications beginning in 1991. The “E” means that it must use an electronic ECU for control, as it will not function without it. The trans has experienced multiple minor upgrades over the years, with the newer boxes being a bit more attractive, but all the versions can be made to work well in a performance application. The addition of electronic control and overdrive adds roughly 50 pounds and a slight amount of width over a TH400, but for the most part, any floorpan that can accommodate a TH400 can also fit a 4L80E. Also, the 4L80E transmission is typically about 4 inches longer than a TH400 (depending on the length of the extension housing), but the trans mount is located roughly 11⁄2 inches rearward.
Old Feb 18, 2018 | 09:36 PM
FFDP's Avatar
Old Feb 19, 2018 | 08:48 AM
Go5.3tt06's Avatar
I see that need make crossmember for Th400. What about vss and safety neutral switch also
Old Feb 19, 2018 | 11:17 AM
Dusty05's Avatar
I'm doing the TH400 swap now. The neutral safety switch and reverse lights can be wired through the shifter. I'm using a b&m pro ratchet.
I had a vss sensor put in the tail housing. I have to swap the plug but it should work fine.
For the cross member I would recommend looking here:
https://www.performancetrucks.net/fo...embers-521976/
Old Feb 20, 2018 | 10:32 AM
Go5.3tt06's Avatar
Awesome yeah i got crossmember from him. Can u inbox me pic how hooked w safety neutral switch. The shift. Can u send me link. Wanna see it
