installed my 4.56's today :-)
Old May 10, 2012 | 05:43 PM
Gadgetized's Avatar
Default installed my 4.56's today :-)
So as the title says, I put in my 4.56's going from 3.73. I calculated everything with an android calculator on my phone, and it said it would be about 2500 at 70. Well it is 2600 so I guess it wasn't too far off. I drove it from my dads shop to my house (about 15 min) real easy as I intend on breaking them in properly. About 5 min after I got home I thought, hey why not check the dif temp. Well it is 55 degrees out, and the bottom of the dif was 122. I was actually surprised it was that hot. For a comparison, the exhaust was 132. I will be taking it for a 30 min drive in a bit, and check that temp. I will also continue to measure the temps during the break in cycle to see what is happening back there if anyone is interested.
Old May 10, 2012 | 05:49 PM
DTHPROOF's Avatar
Awesome man. I thought about that but I'll be spraying and I'll run out of gear. What size tires are you running?
Old May 10, 2012 | 06:31 PM
Gadgetized's Avatar
I have 275/55/20's on it now. I'm going to be spraying a 100 shot too. Let's see if this thing can break into the 11's.
Old May 10, 2012 | 08:18 PM
DTHPROOF's Avatar
Yeah, I run 265/50/20's (30" diameter) and 4.56's are too low for mine. Good luck with your goals buddy!
DrX
Aug 19, 2015 04:45 PM
USMCvet0311
Aug 13, 2015 09:59 PM
black03rcsb
13
Aug 13, 2015 04:05 PM
97aztecgt
Aug 13, 2015 02:11 PM
