Inner Tie Rods
Old Feb 16, 2008 | 02:37 PM
SILVERBIRCH's Avatar
Default Inner Tie Rods
Took my truck to get aligned today and the guy told me that the inner tie rods had some play and that needed to be replaced gave me a quote of $480 for parts and labor is this correct? I went ahead and still got the lifetime alignmentand balance and told him i would check back and see about the tie rods the truck doesnt pull to neither side and the steering wheel is straight only problem is that around 65/70 mph i feel the steering wheel shake a bit i dont know if this can be due to the 22" wheels.
Old Feb 16, 2008 | 03:22 PM
ramsey rider's Avatar
all our trucks are known for inner tie rod beeing bad .just replaced mine
Old Feb 16, 2008 | 04:20 PM
GTOsRamairSilverado's Avatar
i dont think they are that difficult to replace and i dought they cost anywhere close to $400. i would just buy them and replace them myself.
http://www.autozone.com/R,APP406939/...ductDetail.htm
Old Feb 16, 2008 | 04:29 PM
dirt track racer 81's Avatar
jack it up and wiggle the wheels..if they wiggle they need replaced
Old Feb 16, 2008 | 04:40 PM
BlownChevy's Avatar
blownerator
25 Year Member
Nice find, I am in need of the same thing
Old Feb 16, 2008 | 08:15 PM
BlownChevy's Avatar
blownerator
25 Year Member
I see the 2004 has a different inner listed;
http://www.autozone.com/R,APP402768/...ductDetail.htm
Old Feb 16, 2008 | 08:46 PM
BlewSilverado's Avatar
I had mine replace once under warranty and then one failed again just after the warranty expired. I replaced them the second time with Moogs I got from summit for about $50 each. They are noticbly stiffer and have worked like a champ for over 30k. I have a friend that is a GM mechanic he says the stock units suck. They were not hard to install. You will just need to go straight to the alignment shop after install.
Old Feb 16, 2008 | 09:24 PM
BlownChevy's Avatar
blownerator
25 Year Member
got the moog part number?
Old Feb 17, 2008 | 06:39 AM
Allgonoshow's Avatar
same as duralast, [actually duralast uses moog #'s]
definitely use moog parts
Old Feb 17, 2008 | 07:01 PM
Do you need some kind of special tool to change them out if i do were can i rent one and are mooogs available at any auto parts store i think im going with the mooogs i heard pretty good results of them.
