If you say Transmission.....
Old Apr 8, 2009 | 03:57 PM
  #51
viciousknid's Avatar
Where's the Beef?
yea I know.
I took the plugs out and heated them and was able to push them in easily. You can tell that the sealant **** that is on them is whats making it tough.
Still not recognizing P tho. Gonna go ahead and replace the plugs and take the PRND switch off in an attempt to clean the pins up in case. I think that gunk is on the pins.
When I first key on it has the little line under P. after about 8 seconds the line goes away like it isn't in park and won't try to start.
Old Apr 17, 2009 | 01:52 PM
  #52
stevenc's Avatar
Any update bro?
Old Apr 17, 2009 | 10:24 PM
  #53
Where's the Beef?
I adjusted my shift points a little to be more precise and cleaned up the gunk out of the plugs with some WD-40 and tiny screw driver. It recognizes P and D right away but has to sit in R for a few seconds before the doors will lock and indicator lights up. It still don't recognize being in 321. (just the indicator, trans still does).
I'm going to make sure I didn't pinch anything and unhook the neutral switch again to make sure the pins are clean.
As far as shifting goes its fine when driving normal. If i get up toward 3/4 throttle or more is when it starts to slip doing 2-3 shift.
I'm taking it easy on it and avoiding going that far on the throttle until I can get some more money saved up and get the Neutral switch working properly.
It's not as bad as this video shows anymore but still doing it.
lady3bglover
Oct 9, 2008 06:58 AM
ranwalk
Nov 8, 2005 09:29 AM
