I want the 4l80!
In addition to what was said above about converting one of these units you will need to add the lube orifice to the back of the case and also make sure you have a rear planet with the VSS ring on it. This is what is used to lube the extension housing bushing in a 2wd model. There is some more info on this topic in this thread.https://www.performancetrucks.net/fo...nce-493876/HTH Vince
