I need a new rear end!
Old Jul 11, 2007 | 06:11 PM
Turbo 6.0's Avatar
Default I need a new rear end!
What kind of rear end came from GM that will bolt into my 2004 1/2 ton silverado that is 6 lug with a posi? Anyone? I plan on having 800+ to the tires when it's all said and done.
Old Jul 11, 2007 | 06:20 PM
blake2kz71's Avatar
what you mean you need a rearend? Like just a new carrier & ring & pinion or the whole rearend? The 99- 8.6 in the half ton trucks & suv's will work. And most came with the g-80.
Old Jul 11, 2007 | 06:31 PM
BlackLM7's Avatar
Your truck came with a 8.6, 30 spline rear end from the factory. The only vulnerable part is the factory G80 posi. Swap that out for an Eaton LSD or Detroit TruTrac and you'll have a pretty stout rear. You could always buy a TA performance cover to add even more strength if you want to.
Old Jul 11, 2007 | 06:39 PM
vanillagorilla's Avatar
You're making some pretty decent power, and I'm sure with more to come. You might what to seek out the holy grail of rear ends for our trucks. That is, the 14 bolt SFF rear end that comes in the new Vmax and SS 2wd trucks. They're pretty hard if not impossible to find used, but you can order everything else new from GM. It just gets pretty pricey that way. Also the stock G80 is those is somewhat questionable.
Old Jul 11, 2007 | 06:43 PM
blake2kz71's Avatar
Iv got the tru-trac and t/a cover in my stock 10 bolt and its been fine. Im not makin much power though but I think youd be fine.
Old Jul 11, 2007 | 06:57 PM
ZZebes's Avatar
the SS 14 bolt semi floater is pretty indestructable and can be had drum to drum from gm for somwhere around 2 grand loaded with 3.73's or 4.10's
i have the part numbers somewhere and if you plan to keep your stock ds than you need a little bastard of a u-joint from napa.
The NAPA U-Joint part no. is 240-0447
Old Jul 11, 2007 | 07:44 PM
Derek @ EDO's Avatar
FormerVendor
parish put down how much power with his eaton and TA covered 8.6?
i think you will be jussssst fine lol.
Old Jul 11, 2007 | 07:51 PM
nightrunner's Avatar
Mr. Obvious
remember that was through TWO 10bolt axles, four wheel drive, and a 3/4ton transfer case
no doubt, 4wheel drive splitting the torque between two axles made that live but id say you could go to about 600rwhp in 2wd on the 10bolt in a rcsb truck. but if 4wd you have nothing to worry about
Old Jul 11, 2007 | 10:01 PM
quicksilverado's Avatar
All of his dyno runs were in 2wd. My stock rearend held up to 600rwhp for a year and about 70 passes before the posi grenaded. An aftermarket posi and the 10 bolt is pretty stout.
Old Jul 11, 2007 | 10:29 PM
onebadrubi's Avatar
Dyno's dont come close to the stress as a 1000rwhp launch. I highly doubt a 10 bolt with a upgraded posi/gears and cover will hold a 800+rwhp hooking launch more then a handful of times.
Two have tryed it that come to mind and both trucks are running ford 9".
