Hydroboost Conversion Install
#53
High on diesel fumes
Here's an analogy that's kinda similar to a brake burnout.
You're coasting down a steep hill, and downshift to help slow down. You also apply the brakes. Now you're running along at high RPM with the brakes applied. Why would that be ok, but doing a braking burnout wouldn't? Same deal both ways.
#57
#58
This is definately on the to-do list!!! I've been wondering why the hell everytime I get out of the company truck ('05 HD) and get into either one of mine, that the brakes seem like they're not there!!! The HD stops on a dime and my truck takes a lot more pedal to stop. I definately want to do this to my Z71 and considering the same for my black truck, since I might go FI.
#59
As far as the keeping the PS fluid cool, do what I did. Get a used F-body liquid-to-liquid PS fluid cooler and install it in your upper radiator hose between the water pump and radiator (like it is installed in the F-body). They work like a champ by both bring the fluid up to temp quicker and then keeping it at the engine coolant temp.
#60
ok a few questions. my truck has a sensor at the bottom of the resivour, is that still accounted for? also i noticed on my friends 03 truck he as a little canister that sits off the brake booster. is that the thing that was causing message problems?
