Hydroboost Conversion Install
#112
A Couple Questions...
Would all these components apply to an '88 thru '98 GM truck?. Can an LS1 style power-steering pump be utilized in this system, as I see only the Delco style pumps in the photos? If your tooling down the highway, and your engine stops running, say you run out of gas or an electrical/computer issue surprises you, will you still have manual, unassisted brake capacity? By the way, great write up. Thanks
#116
I have a gauge for that
Im going to the salvage yard tomorrow to pick up a 14bolt sf, and want to grab some stuff for this while I am there.
All I need is the hydroboost, master cylinder, and optional power steering pump, right? Just get the lines new from autozone, aap, etc?
I am a bit confused about the vacuum cap....the pictures arent showing up so could anyone clarify that?
edit: eh they are cheap as hell anyway.
#117
Vacuum cap? Don't know what you mean. Maybe someone just means to cap off the fitting on the intake where the old brake booster vac hose went? Not needed with the HB setup.
#118
I used the HB to Rack hose from a van. Worked great.
Yea, vacuum cap for the port on the intake where the break booster vacuum hose was.
