Hydroboost conversion
Old Nov 23, 2012 | 02:19 PM
VorTecxas's Avatar
Default Hydroboost conversion
I'm putting the Hydroboost from a '98 Suburban into my '96 Sierra halfie. I'm swapping over the PS pump, master cyl, and booster. Do I need to switch out gearboxes also, or will mine work with the setup? I have the whole Suburban, so anything I need I can swap.
Old Nov 23, 2012 | 06:37 PM
TIM Z's Avatar
11 sec. Truck Mod
Gear box should be fine , but I'm sure you will need the brake pedal from the burb also .
Old Nov 26, 2012 | 07:54 AM
VorTecxas's Avatar
Do you mean the rod? Are they not removable like the older ones?
Old Nov 26, 2012 | 08:32 AM
03sierraslt's Avatar
No you have to change the pedal assembly also as the pivot point is different. To the best of my knowledge anyway.
Old Nov 27, 2012 | 09:12 AM
VorTecxas's Avatar
All right, I'll check it out. Thanks for the help ya'll
Old Nov 27, 2012 | 10:17 AM
Peyton676's Avatar
You can modify the stock pedal,but its worth it to just get the pedal,even if you have to buy new for $35
Old Dec 1, 2012 | 12:28 PM
VorTecxas's Avatar
Yeah I'll just take the one off the 'Burb. I'm scrapping it when I'm done anyways
dantheman1540
Nov 1, 2015 02:59 AM
GMCtrk
18
Oct 6, 2015 03:48 PM
Silver8ado
Sep 30, 2015 11:42 AM
spooneralmighty
Sep 11, 2015 02:28 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
